メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
467回答 すべてを表示
Drive Won't Mount, Need to Recover Data
Hey @danj, I read Hard Drive Issues: Code 8. What does it mean? post you answered a couple years ago, which is similar to the issue I’m having. You mentioned “Often times I see this with BootCamp installations when a Windows virus attacks the drives boot sectors.” This client previously was running Bootcamp.
I have replaced the HDD, reinstalled OSX 10.13.x, but I’m trying to recover the data from the old drive. I have it connected externally to my mac. It won’t mount in Disk Utility or diskutil mount. First Aid always fails with a code 8 or something else. I have tried verifying volumes and fsck.
At this point, is there any way I can get any data off this thing? You mentioned making a Time Machine backup and then reformatting, but I don’t even know how that’s possible without being able to mount.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sadly, that’s the end of the drive ;-{
Maybe a data recovery app or drive recovery service can fix the drive enough to allow you to recover the data.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I used Drive Genius to check for physical errors and it spit out a list about as long as a CVS receipt. Oh well!
さんによる
コメントを追加
回答を追加する
Alex Robinson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 34
