I get no signal from graphics cardwhen starting my pc some times.
I sometimes get no signal when starting my pc. I need to make a close the pc from the power button and get the signal. mayne times it needs more than 1 tries to succeed. Other times it starts normally.
I tried changing HDMI ports, i cleaned the ram, i even changed the monitor but the problem occurs. I have to say that i have a monitor and a tv connected to my computer. When the problem occurs neither of them gets signal.
My graphics card is Gforce 1050 ti
Anyone can help me fix this?
Hi oblisgr
let us know the specs of your computer and power supply.
sometimes if power supply wattage is low, it may cause this weird issues.
you can test your graphic card with 3dmark furmark ... burn in test to check for stability
Augustine さんによる
Well my power supply is 600W
I have 3 external disk drives and an internal.
My cpu is i4440 3.10 ghz
ram is at 8 gb
oblisgr さんによる
Hi need more on your power supply made and model number,
Augustine さんによる
