メインコンテンツにスキップ
The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
23回答 すべてを表示
Delonghi Perfecta ESAM 5400 Steam or Hot water not being produced
(the loose connection was me taking it apart)
The hot water steam function is not currently working and I am suspicious of the solenoid. All the hoses are free of blockages and look clean. Hot water comes out of the “in” hose if I unclip it but nothing comes out of the “out” hose side of the solenoid if i unclip that hose (once i’ve reconnected the “in”!). Does it sound likely that the solenoid is the issue? Is there a way to test without ordering a replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I have an ECAM model with the same valve and same problem. Remove the valve, remove the solenoid by removing the top nut, remove the solenoid actuator the rinse out any material blocking the valve base. That was my problem. If the solenoid coil is no longer working they can be readily bought online.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks Geoff, i forgot to return to this post after fixing it but it was indeed the solenoid coil. Easy fix in the end
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maxwell Hill さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 33
今までの合計 841
