メインコンテンツにスキップ
2019年3月に発売されたSamsungの10世代になるGalaxyの新モデルです。OSはAndroid 9.0 (Pie)。
74回答 すべてを表示
My screen is destroyed. Can it be fixed or my photos salvaged.
It fell and landed square on a rock the damage went through the screen to the point that I can see a bit of the guys. Is it fixable? At least to the point of getting my pictures off of it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You will have to put a screen on it to find out. Most likely it can be fixed. If you are going to do it yourself buy a good quality screen WITH A FRAME. It makes it a lot easier to change and you don't to worry about sealing the screen because it already attached. You got heat up the back and cut the glue on the back battery cover around the edge with something thin like a guitar pic. Remove the mid frame with a bunch of Phillips screws then a couple of screws and the motherboard and misc electronic parts. You can get multiple repair videos on YouTube and swap everything over. You may need a new rear cover if you crack it but it's only a few dollars. If you don't think you can do it or don't want to you can check with a local repair shop or you can mail it in. The two people I recommend is jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com. I hope that helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TYLER COWIE さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 67
