メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HPが2016年10月に発売した人間工学に基づいたノートパソコン(モデル番号:15-au123cl)です。Windows 10を搭載し、タッチスクリーンを備えています。
Boot device not found
Hi,
Please I need your help. I did a Windows upgrade from 8 to 8.1 and after the upgrade I wasn't seeing wifi connections so I tried to resolve this myself. With the suggestion I got from the virtual assistant, I did a BIOS configure and saved the default settings. Now I can't boot my PC. It keeps saying Boot Device Not Found. Please what do I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Start the laptop and then quickly press the Esc key followed by F10.
This should get you into the BIOS menus.
When there check if the BIOS has detected the HDD.
If the HDD is shown in BIOS I’m not sure with the BIOS in your laptop but once in there it should show which keys to operate to reset the BIOS to the default settings. Try doing that, save the changes and then restart the laptop and check if it boots OK
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Thank you for responding. I only saw press F9 to set default which I did. I still can't get pass the booting error
さんによる 共有
@jesseyb
Try to perform a startup repair see Method 2
さんによる 共有
Easier to press Esc. It's the magic key on HP products. That said, the key is usually F10 on the modern ones.
さんによる 共有
Finally my PC has booted. I change the boot mode from UEFI to Legacy and it worked. So what do I do next? Should I still do the startup repair? Do I need to change back to UEFI or leave it as it is now?
さんによる 共有
@jesseyb
If it boots OK and it all works OK and that you can restart it in the usual manner after you have shutdown in the usual way then it should be OK so change it back to uefi and see. If not OK when you do this you may have to do the startup repair in case something else has been corrupted
さんによる 共有
4件以上のコメントを表示
コメントを追加
回答を追加する
Jessey Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 1,214
