メインコンテンツにスキップ
モデル番号A1320/8もしくは16GB容量
20回答 すべてを表示
Screen Locked
PLz man tell me key of screen lock in ipod model:A1320
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
3 件のコメント
tonkas, there is no default "key" it works better if you ask your own question. Click on the link on the right side of this screen Ask a Question" and give as much detail as possible. Have you tried any of the above steps to unlock it?
さんによる
Sorry mate, the code is personal. There’s no universal unlock code (except for erasing it)
さんによる
Kaki otkljucati ipod A1320 Lea's
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This is my answer for most of these disabled iPods. You can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared, again not sure if it works for a disabled one. Sorry if you use a Mac....can't help you with the steps on there :-) the other thing you can do, if you have the computer that you always use for this ipod, is to simply restore it
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
If you have a Mac go into finder, select your iPod (choose the drive with your iPod’s name not the iPod icon) then press CMD+SHIFT+period to show hidden files, your iPod_control folder will be there
さんによる
did not expect that to work but wow... it did
さんによる
コメントを追加
回答を追加する
tonkas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,793
