メインコンテンツにスキップ
車両やトラック用のスピーカー、ヘッダーユニット、CDプレイヤの修理ガイド。
247回答 すべてを表示
Why does my new pioneer radio doesnt turn off?
Well i bought a recent and new pioneer radio for my car and i also needed an harness adapter so i bought it too . the when i pluged all together my new radio stop turning off when i removed the key but my old one did turned off when id do the same thing …Anyone can help? suposedly i didnt have to reconnect a wire to my ignition switch right?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You should have a an orange or yellow wire that is battery power which should be on all of the time. The red wire is ignition and should only have power when the key is turned on. On the adapter it should have the same color and say ign on the red wire and the orange or yellow should say bat on it. Hook up those the correct way it it should work fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I already measure the volts on my original harness and I don't have any pin that turns of with ignition but my older radio and original one did turn off any help?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You have probably blown the fuse. You need to check the wiring schematic from the radio and the adapter and connect them together the same way. If you can't figure it out you should probably have a shop take a look at it.
さんによる
コメントを追加
回答を追加する
Tiago Mendes さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 44
過去 30 日: 210
今までの合計 3,330
