メインコンテンツにスキップ
廉価版で携帯バージョン、統合されたJoy-Conコントローラと若干縮小したスクリーンを持つNintendo Switchハードウェアです。2019年9月20日発売。
175回答 すべてを表示
Right bumper is stuck in a pressed position.
The right bumper button, not the trigger - the one above it, is stuck in the pressed position.
  • It doesn’t seem to cause any reaction in the game, so I’m not sure if the contacts are being touched.
  • Bumper doesn’t rebound when pressed, so maybe that mechanism has slipped away or ???
What’s the right way to fix that? Replace the button? Throw this thing I didn’t want my kids to have against the front window of the grandparents that bought it for them?
Cheers.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
最も参考になった回答
I found this fix on youtube, it sounds funny but has actually worked for multiple consoles.
“I fixed mine and it’s been stuck for a month. I basically did CPR on it. I blew along the edges and awkwardly put the entire L button in my mouth then did one big blow. Then inhaled after and it popped back up.”
I know it sounds ridiculous, but this technique worked on my switch lite after the R button had been stuck for months.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
It's not ridiculous at all. It's like using a toilet plunger to pull dents out of a car. Depending on the type and severity of the dent it works. Occam's razor right? Sometimes the simplest (and even silly seeming) solutions are in fact the solutions.
さんによる
Thank you so much i looked this up and i found this i tryed it and it worked thank you so much i wish you a beautiful life
さんによる
Wow tysm it actually worked
さんによる
thank you so much i thought o would have to buy a new one
さんによる
wow this is hilarious it actually worked!!! 🤣
さんによる
1以上のコメントを表示
コメントを追加
Sounds like it already got thrown. :) Either it’s jammed (gunk, whatever) in which case “unstuck” it. Or the plastic button itself is broken, replace. Or the button module is broken, re-solder or replace. Or the the pcb around the button module is broken, dead. The shoulder buttons on the switch cons are poorly, cheaply designed. Good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Could be that the spring is stuck/snapped. Should just take the back off and remove the trigger assembly, then see if the spring is there/moving.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try getting canned air and spray some in the Gap between the it and the device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You might just have to get new controllers because even if you try it fix it it will get worse so might be better to get new controllers.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
GB Lott さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 60
過去 30 日: 251
今までの合計 12,698
