How do you replace a solenoid switch?
Diagram of solenoid switch
I assume it's for the starter. It's either going to be part of the starter and if it's not follow the battery cable from the starter and it should lead you to the starter solenoid. It should be obvious how to change it but before you do anything disconnect the negative battery cable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 241
