メインコンテンツにスキップ
The Asus VivoBook S400C is a touchscreen laptop released in October 2012. This model is identified by a sticker on the bottom of the device as “ASUS S400C Notebook PC”.
3回答 すべてを表示
How do you remove this kind of Laptop LCD connector
Guys I have a Asus Vivobook X411UN and I'm trying to replace the LCD. But the problem is I don't know how to remove laptop LCD connector pin.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi,
Post a close up image of the connector
iFixitでの質問に画像を追加する方法
さんによる
Done posting
さんによる
コメントを追加
3件の回答
最も参考になった回答
@razankasglen
Don't know the answer so hopefully someone else will.
Perhaps if no one else answers, since you have to replace the LCD screen then maybe just disconnect the cable from the LCD screen end only and connect the new screen to it.
Looking at the replacement cable it seems that it can be removed from the LCD and is not permanently connected to the display assembly as some are.
Perhaps it may be easier to get at.
The part number for the cable is 14005-02440100 found on this website
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thanks for the picture. There are two shoulders on the cable connector that provide a place to push on to remove the connector. I'm assuming it's similar to the one used on the S400C in that being taped down it almost certainly doesn't have any kind of latch.
Take a couple of spudgers and place one at each point of the arrow and push them both evenly in the direction of the arrows. It should simply slide out - it may take a little bit of force; I know the S400C does.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just pull the sticker to the point shown in the image,
Then pull out the lego type connecter little by little, by pulling left and right side of the connecter little by
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
razankasglen さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 32
今までの合計 2,494
