メインコンテンツにスキップ
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
Removing 128GB SSD From MacBook Pro 2017 into a Reader?
Hello everyone,
Recently my wife spilled some some water onto her MacBook Pro and it won’t turn on currently.
Is there a way to take the Apple 128 GB SSD and place it into an enclosure to read it on another mac by any chance? Or, can I use MacBook Pro can I swap out the drive get her items off?
We both have 2017 Macbook Pro 13” systems. I tried searching for a case but didn't see it.
This is the drive I took out:
https://imgur.com/a/PJyPifZ
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Try to look for a reputable independent repair shop in your area, they usually have means of transferring data. Might be easier than finding an enclosure.
さんによる
Thank you for the reply as well! I’m going to swap out hard drive from her mac to my Mac @pomikoli
さんによる
コメントを追加
1 件の回答
ベストアンサー
@antdogs - Sorry to say there is no adapter cases to hold this version of Apple SSD.
If you both have the exact same system (both are function key models) then you could swap over the SSD drives. Before you do make sure you’ve made a backup of your systems data as well as create a bootable external drive as you may needed it to salvage your wife’s drives data.
Follow this guide first steps (1 ~ 15) MacBook Pro 13インチ Function Keys 2017 バッテリーの交換
Then disconnect the left Speaker unit and remove it which is just in front of the SSD Drive, Peel off the tape from the drives case and the logic board connector and remove the two screws holding it in (I would mark your wife’s drive with a sharpie marker so you know which is which.
Follow the same process on your system. Reverse the procedure installing your wife’s drive in your system and hopefully it starts up. If not use the external drive you have setup. Good Luck!
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Ahhh thank you! I was looking through for hours and did not see any adapter/external reader like i do with my esata hard drives. I already took the hard drive out of her computer, I wanted to be sure if there would be be any conflict if I put her hard drive in my machine. I will try this today and boot up her hard drive on my machine and copy items over.
thank you very much!
さんによる
@antdogs - Let us know how it goes!
Don't forget to score the answer and accept it if you if are up and running!
さんによる
I definitely will! One more question both of our computers aren’t encrypted, so when I boot up her machine it will be like her computer turning on correct?
さんによる
Yes, it should! You will need to use here user account and password to access the files.
さんによる
Awesome thanks so much! I will do that today and let you know!
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Anthony Thornton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 1,490
