Why does my light go bright then dim and Bright then dim?
I want my to stop flickering bright ,dim ,bright, why? I just want it to work right.
Most likely there is some corrosion or loose connection. Follow the complete teardown instructions including the added comments. A q-tip with vinegar goes a long way when it comes to Maglites. You just need to take it apart completely including the DO NOT REMOVE tab and clean all the parts thoroughly. Good luck.
このアンサーは役に立ちましたか?
Thank you I have no idea what I am doing
Just stay with me all the way
What do I need to do next
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 531
