メインコンテンツにスキップ
Thermal fuse / vent ducting
I have the Maytag MEDEX655DW1, 2 years old.  Dryer quit running and I found the thermal fuse was blown; replaced it, hit start and it ran. I immediately stopped the unit and hook back the vent duct and started to dry a load.  When I came back to check the top of the unit was scorching hot so I turned the unit off. I unplugged and unhooked the unit from the vent duct and cleaned / vacuumed all lent throughout.  I then ran the unit unhooked from the vent for about 30 minutes on high heat measuring the temperature from the center of the exhaust. The temp built to 142 degrees and I was satisfied so I hooked vent duct back up and I ran a load on air fluff.  The temperature had heat in it.
The unit is installed on a interior wall about 8’ from a exterior wall. The duct flows through the floor and is the flexible foil type and does not reach the exterior of the house or have a cover on the end under the house. I ran a brush through the vent from the inside and saw it reach the other end.  I plan on replacing the duct today but my question is would that be the reason for the overheating and why would it heat up on air fluff?
…after all that I decided to stop all drying till I replace vent duct and test again then my wife decided to run a load on high heat and the fuse blew again…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Hi @bobbyj2x4
If the thermal fuse is operating it means that the hi-limit thermostat - part #15 bulhead parts isn’t operating to prevent the dryer from overheating. The thermal fuse is the safety backup in case the hi-limit thermostat doesn’t operate.
There is also an internal bias thermostat (part #8 in link above) that should regulate the dryer temperatures that you may want to look at as well
These quotes are from the parts supplier:
This thermal cut-off prevents the dryer from overheating when the dryer high limit thermostat fails in a closed circuit condition
This high-limit thermostat acts as safety mechanism to keep the dryer from overheating. Once the dryer temperature reaches 221 degrees Fahrenheit, this piece will shut down power to the heating element until it drops by 80 degrees Fahrenheit. Once the temperature decreases, the thermostat will restore heat in the dryer.
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi guys. Does anyone know how to fix the ventilation system?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey, bro. I recently did repairs in the house, but I did not check the ventilation. I was sure that she was all right since we had only recently bought the house. But during the repair work, it became clear that the air circulation was working poorly. As a result, dust and the smell of building materials did not get out of the house for a very long time. The situation only got better if we opened the windows and doors wide open. So I called the service https://epicductcleaning.com.au/ responsible for cleaning and duct repair and asked them to check our ventilation. It's good that we noticed this during the repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bobby さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 20
今までの合計 299
