メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
375回答 すべてを表示
iPhone XS Max randomly turns off after around 5min (Not Charging Port)
Hello,
I have an iPhone XS Max brought in by a customer that randomly turns off after 5min. I have looked at previous answers that have said the issue is the charging port however in the two cases I have, the iPhone has never been opened and thus the charging port is OEM, the same one that came out the box.
I have replaced the battery which worked for around a week before eventually reverting back to randomly turning off. I also have replaced the charging port just to check. I used another OEM one and the issue persists leading me to believe its the motherboard.
Upon inspecting the motherboard I haven’t found anything significant however maybe i’m looking in the wrong direction.
If anyone has had this issue before and fixed it please let me know! :-)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
+ In one case the iPhone has been dropped, the back cracked but aside from that, fully functional. In the second case the iPhone wasn’t dropped or anything, the problem just developed.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It could be a lot of things causing it. I would recommend putting the board into a known good housing with known good screen to completely eliminate parts.
You could try and look at the log to see what it was doing before shutting down.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Will try this and update you
さんによる
Did u fix it?
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 446
