メインコンテンツにスキップ
2017年4月に発売されたSamsungの新しいフラグシップのスマートフォン、Galaxy S8です。
304回答 すべてを表示
Is it ok to keep Galaxy S8 365 days a year on charger because HotSpot?
I know it would be better to disconnect daily - but I look answer like - “Samsung officially says DO NOT leave Galaxy S8 for longer than “x” days as it will explode”
I do not look for advise like “ better disconnect it daily” because I need it as HotSpot 365 days a year.
I look for other advises like “open it up - disconnect battery - and S8 will work without it”
But I do not know answer for that question - will it?
I know iPhone not and they will CPU throttle
thank You for help :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Constantly leaving it on the charger can severely damage the battery and cause it to swell up. You could technically connect it to a DC power supply and eliminate the battery but that will look jerry- rigged. Why are you using the phone as a hotspot constantly?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
because it is cheaper to move from WiFi to SIM only (unlimited 4G) here in UK
さんによる
コメントを追加
回答を追加する
Bart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 37
