runs for about 15 minutes then stalls?
My 07 jeep wrangler had the fuel pump replaced.
But runs for about 15 minutes then stalls?
I let it set for 5 minutes then it starts?
Will some times will run for a hour then stalls?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
THANKS.
The shop said it's the crank sensor..
We will see if that's it ??
このアンサーは役に立ちましたか?
I think there might be multiple problems, but mostly it should just be timing or some issues with the computer, because i have a skoda superb that had it’s computer replaced because of a similar problem, or you can also try to check your wiring
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 142
