メインコンテンツにスキップ
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
77回答 すべてを表示
2006 expedition king ranch 5.4. 3 valve
Was having problems with misfires I replaced the spark plugs and all the coils and cleaned the throttle body now I’m in Failsafe mode it’s got 7 codes now cam sensor both sides ,mass air , o2 sensor both sides upper , throttle what do I do now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What spark plugs did you use? Brand and model?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
motorcraft plugs
さんによる
fail safe code came on truck will not start
さんによる
Make sure you use the same spark plugs that came from the factory. It can cause run problems with the wrong plugs. Make sure you have the correct plugs and erase the trouble codes and see if it will start. If it starts see what codes come up. If it doesn't start see what codes come up. Message me back with the codes and let me know if it started or not.
さんによる
コメントを追加
回答を追加する
john Distasio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 48
