メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
20回答 すべてを表示
Power issue - Falsely showing 100% charge
The first issue I had was the laptop was only running on AC, and it was not charging at all. Upon investigation found out, that possibility is my charging cable is bad, because the cable was badly damaged too.
I purchased a replacement charger.
https://www.amazon.com/dp/B07RB2HTB2/ref...
Now that it is charging and showing 100% charged, as soon as I remove the AC, it goes to sleep. When I put AC back on and power back up, it comes back says 5% charge and charging.
My question is do you think it is issue with battery?
Now if this is a battery issue, I have to buy one. As as I was doing research it seems 9350 supports 7.6V battery.
However the aftermarket replacement battery that i could find in ifixit is a 7.4 V battery. Do you think it would work?
Dell XPS 13 9343/9350 Laptop Battery
Thank you in advance!!!
Replace a 6930 mAh battery compatible with Dell XPS13 9343 9350 model laptops. 52 Watt Hours (Wh). 7.4 Volts (V). Part #5K9CP, 90V7W, DIN02, JD25G, JHXPY.の画像
製品
$69.99
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @soumyajit ,
Create a Win10 battery report and check what it shows regarding the condition of the battery.
If it needs to be replaced search online for 90V7W to find suppliers of the correct battery for the laptop. This is a 7.6V 56W battery.
Here’s the ifixit Dell XPS 13のバッテリーの交換 guide for a Dell XPS 13 (9343/9350) which may help.
If you click on the magnifying glass in the image at Step.8 in the guide and then click on the image again when it opens in a new window you can see the battery model number printed on the battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you very much for the reply. I replaced with a 7.6V battery from amazon. So far every thing is good.
さんによる
コメントを追加
回答を追加する
Soumyajit Ray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 257
