メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
495回答 すべてを表示
No service on my iPhone
I recenty bought an almost unused iPhone 11 that had a screen issue. I changed the screen myself and everything seemed to work workperfectly when I assembled it together.
The only issue i’m having is that my iPhone keeps saying no service. it may have one dot for maybe 5 seconds when turning flight mode on/off or when I reboot the device, but after 10 seconds or so it says no service. In cellular settings I can confirm it is the right network, and it reads the sim. I get asked for the pin code when putting it in.
I have also tried another SIM card in my device and its still the same issue. I tried using my sim on my older phone, and it works in that device.
So i’m guessing it is a hardware issue or something like that. Please help! Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
Since it is asking for a sim pin, the device is “locked” (not actually, but functionally) from your network. If you have Sprint (or I guess TMobile now) your sim needs to be “activated” for that device on their end.
You can do this from the website in many cases as long as you can provide the imei number and the number from the SIM card.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have the same issue here on my recently purchased 11. No carrier lock on the phone but it only accepts one network (Cell C) other sims register but show no service with symptoms listed above. IMEI has not been blacklisted. Can anyone help?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem, i need help to
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I will try to replace the SIM reader and I will send to you the feedback.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Şebekede sorun yaşıyorum yüksek internet gerektiren uygulamalarda çok fazla gecikme ve ping yaşıyor kullanamıyorum aynı sim kartı ve aynı telefona sahip herkes kullababiliyorken ben kullanamıyorum.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mathias Fadnes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 534
