メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
375回答 すべてを表示
Front camera not working after logic board replacement
Hi all,
I replaced the logic board of my iPhone XS Max and now the front-facing camera is not working.
I understand that, after replacing the logic board, only FaceID will not work. However, I have never heard that the front-facing camera will not work as well.
In this case, do I have to replace the front-facing camera as well?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I have change the motherboard and housing of my xs max... But after all been set up front camera and taptic engine stop working.. but something strange happens. When the phone is cold while charging the taptic engine works and then stops working...My plan is to change both parts and try to update
さんによる
コメントを追加
2件の回答
ベストアンサー
I can agree that the face-ID will not work but I couldn’t imaging the front facing camera fully not working if you have another camera try and swap it to see if that makes a difference or try your camera in another XS Max if the camera works in another phone you have a issue with the logic board, but if a new camera works in your phone then it is just the camera that is damaged.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you for your comment.
Unfortunately, I don't have any spare phone to test this. But I think that it is highly likely that my front-facing camera is broken.
さんによる
Yeah there is a good chance mate No matter what the issue is with my device i always rule parts problems out first as they are always the easiest to fix & test.
In my opinion.
Let us know if you solve your issue.
さんによる
コメントを追加
Hi there
For feedback, i had the same issue, i moved one motherboard from one xs max to another, and had the front camera problem, then i swapped the part and voilá!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Supapat さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 2,737
