メインコンテンツにスキップ
HP's notebook comes with an Intel Core i5 processor, Nvidia Quadro K1000M GPU, and a HD+ display . This high functioning mobile workstation was released in 2012.
9回答 すべてを表示
Why does the charger for not work and how to fix it?
my device is actually the 8470p but there isnt a tab for that on here (at least i couldnt find it) the charging cable randomly stopped working but other chargers do work. how can i fix my cable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
With the charger plugged in go slowly along the cable bending it to see at what point the charging light goes out.
That is where the break is.
If you are able solder you will know what to do. Often these breaks are right at the power “brick” or at the connector and are very hard to repair.
Just buy a new charger because if the repair is done incorrectly you could damage the battery or worse the laptop.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Luke Carlin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 136
