メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
iPhone suddenly unable to read battery health and randomly reboots
Just happened a few minutes ago. The iphone was hot to the touch, so I put it on my table while listening to music, a few moments later i hear my earbuds say disconnected, when i checked my phone it was on the apple logo. I continued using for a minute and then it rebooted. After that I went to check battery health and it says “service, iphone is unable to determine battery health. ( earlier this year I bought two new batteries for my phone the brand was called brand is HDCKU ) . So i have another iphone se that isnt used with the other battery and switched them. I then hard resetted my main iphone se but it still said service. My other se said battery capacity is at 100% on both batteries. Im thinking the heat might have damaged my main iphone se. What do I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The phone getting hot and not being able to read the information from the battery would point to the Tigris IC it is part of the charging circuit and will require a repair shop that offers microsoldering. For the SE it would probably be cheaper to upgrade.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It sounds like a bad battery. Where did you buy the batteries from? I would recommend getting a quality battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
As I said before, the batteries are completely fine, my other se tells me that they work at full functionality
さんによる
コメントを追加
回答を追加する
Brayden S さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 225
