メインコンテンツにスキップ
Pixel 3a XLはGoogleの第3世代バジェットフォンのうち大型モデルです。Googleの最先端カメラと同じものが搭載されています。クリアリーホワイト、ジャストブラック、パープリッシュの色から選べます。2019年5月発売。
15回答 すべてを表示
Is the pixel 3a volume flex ribbon cable interchangeable with the 3aXL
Hi guys I accidentally purchased the wrong part for my pixel 3aXL… I bought the pixel 3a volume flex ribbon cable instead of the 3aXL. However, the flex cables look very similar…the buttons are in the exact same placement as well as the circle cut pass-through alignment points…there is a slight difference in the cut outs on the sides… but I don't think it should affect fitment. Does anyone know if these are interchangeable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I tried to assemble the pixel 3a volume flex cable and there are a few differences...
It's not quite as wide so it actually doesn't fit into the housing as well. it's incredibly difficult to get the fit for the buttons to work right. Additionally the cable is not quite as long as either, however the buttons do you line up in the right area.
The biggest problem is that the male to female connection from the ribbon cable to the motherboard does not actually lineup and is off by about 2 mm.. if I were to make it fit I would have to make a hard bend to the ribbon cable which I'm sure would damage it.
... So in a pinch I would assume that someone would be able to make it work... but I would definitely feel more comfortable just buying the be part.
Just and FYI for everyone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Yes it’s same cable for pixel 3a and 3axl
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you David, you rule!
さんによる
Unfortunately David, I tried to assemble the pixel 3a volume flex cable and there are a few differences...
Thank you tho!
さんによる
コメントを追加
回答を追加する
Brandon Watkins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 131
