メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542回答 すべてを表示
Monitor Says No Signal But Pc Is Running
Hello! I have problem with my pc over half year, I don't have money so I can't buy the repair of the computer in some service. Simply, when I boot PC on the pc works for some time but after some time it shows no signal on the Monitor but the PC doesn't shut down it just runs. Also now I can't even load windows, because I turn on the pc and it instantly shows no signal on the Monitor. Then it gives me 1 long 3 short beeps after trying to reboot multiple times. I tried to use different monitor cable, I tried to reset ram, I tried to factory reset, I tried to change the port for the monitor. I'm really disappointed and I would be really happy if any of you could help me with this. Thank you for your answers in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
First of all tells us what the make and model number for the motherboard and video card.
さんによる
コメントを追加
1 件の回答
It could be the PSU, and if you are getting no display if your motherboard has no built in graphics card it could be the GPU, keep narrowing it down. Try the GPU in a different system if it supports it, or try a different PSU that has enough power.
There are several possible causes for this error. To fix it, you must determine which component is defective
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Uniqq hns さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 613
