Adam Cope ... i will concede to others analysis, but this looks like panel failure. specifically, it looks like a tab gate driver is failing. if you were to remove the bezel to gain access to the displays tabs/ cofs, that freeze spot will be directly in line with the tab on the left or right side of the display.
there are a couple of attempts to fix this by whats called the cut tape method. you can google/ youtube this for reference.
jostewcrew さんによる
