メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
Front Camera not working after replacing screen
I replaced my iPhone 6s Plus’s screen including camera, sensor [works], and call-speaker [works] with OEM.
All flex cables are intact and undamaged.
I’ve read some posts about that it might be related to a grounding bracket.
I can’t find any information about the location of this bracket on the 6s Plus.
Any idea what might be causing it and how to fix it?
Things i’ve tried:
Force closing Camera App.
Restarting Phone.
Settings Reset
Factory Reset
Upgrading to latest iOS [13.6]
Using different video apps [Facetime & Whatsapp]
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Have you tried to put the old front cam from your old screen to the new, maybe the cam on the new screen is defect? Or is the old front cam also defect? This is the first thing you can try.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
The old camera's flex cable was broken which is why I replaced it.
So I can't test this, unfortunately.
さんによる
Try to take the new cam of the screen and put it back on, maybe it wasn’t put correct in by factory
さんによる
@Leslie Leslie
I actually disassembled those parts when it didn't work.
It all looks good.
さんによる
Only thing that left is to buy a new front cam and try that one. I don’t think it is a grounding problem. You might have received a screen with bad / defect front cam.
さんによる
@Leslie Leslie
That's true but I hate paying for it if it doesn't fix it.
Unless there's a good return policy :P
さんによる
1以上のコメントを表示
コメントを追加
I just did a System Info check using Cydia and it does show a serial number for the front camera.
UPDATE: I decided to buy a new Front Camera to see if that fixes the issue.
Will update asap.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Replacing the camera with a brand new camera did not fix the issue.
Any more ideas?
さんによる
コメントを追加
回答を追加する
Nigel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 156
