メインコンテンツにスキップ
Joy-Conは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
167回答 すべてを表示
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
3件の回答
最も参考になった回答
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Did you try updating controllers? It worked for me
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Falling Rose さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 27
過去 30 日: 110
今までの合計 5,764
