メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
369回答 すべてを表示
Screen flickering at low brightness
The S7 edge has in an AMOLED display. Typical OLED displays like televisions do not require a backlight, however the phone has one to decrease screen glare in bright environments. Also to control the brightness of the OLEDs the voltage in the series is either increased or decreased. In a series circuit, the current that flows through each of the components is the same, and the voltage across the circuit is the sum of the individual voltage drops across each component. The damaged screen is disrupting the series causing all the diodes after to freak out. This could be solved if you could control the brightness of the AMOLEDs and the backlight independently but I have not been able to find any settings for this. This could also be fixed if there is a way to do a new baseline on the ambient light sensor to trick the phone into thinking it’s in a super bright environment all the time.
I have also used Lux Auto Brightness to change the light reading from the light sensor to the camera on the phone but has no change on the issue.
Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Sounds like a bad screen to me. Whenever I see screen flickering it’s typically a sign that the OLED panel is either damaged for going bad.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Good thing I ordered the S20 Ultra yesterday
さんによる
コメントを追加
i think it’s normal, happened to me with different devices
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert Honn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 522
