メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Home button not working even with new screen/new home button
Hi!
I have an iphone 7 that I replaced the battery in, removing the screen in the process. When I put it back together the home button didn’t work, not just touch ID but not even working as a button, so I tried the old home button with a new screen, getting the same result. I then tried a new universal home button with the old screen, and also with the new screen, same thing. My only conclusion is that the flex cable connectors are bad on the logic board and that there’s nothing more I can do, being a lowly repair technician with no microsoldering skills. Do you fellow nerds concur or is there some magical fix I haven’t thought of?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If I remember correctly. iPhone 7 and up has the home button paired to the device. So if you damage the cable to the original home button, you are screwed. If this is to be correct, I think the only way to get a new working home button is by having apple fix it.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Except that my very own phone, an iphone 7 plus, I also replaced the home button with a universal one. While it has its quirks, it definitely works as intended, just no touch ID. I got them from Mobile Defenders, though I believe iFixit has them available too.
さんによる
Also no flex cable appears to be torn or kinked in any way. I know through painful experience what that looks like.
さんによる
I guess it could be that I got a bum button.
さんによる
Oh yeah you are right. Only the touch id function will not work with a new flex cable. So if you have tried a new cable, and that did not work. I can only, think of one other thing. That would be the connector itself being damaged somehow.
さんによる
Or you have a damage home button flex cable that runs under the new screen, have you a other screen that you know is good to verify that the flex is still good of the screen that you are try to instal?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Lara Snuffer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
