メインコンテンツにスキップ
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
40回答 すべてを表示
Lenvo Y50-70 Charging Port wiring on mother board
Hi,
My lenovo y50-70 charging port wires detached from mother board , I have to solder it again but there is no wiring connection indication on motherboard . Anyone can please share how to solder these wires on mother board ? which wire for which point?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This may help:
http://www.s-manuals.com/notebook/lenovo...
Have you tried taking a high resolution photo of the motherboard or using a magnifying glass or loupe to look closely at the board. You should be able to see where the connections were. A broken wire end or some other disturbance at the solder pad..
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I checked and came to that charging ics had burnt and I am unable to see ics number as well. Is there anyway to get charging ic numbers?
さんによる
Hi @Muddaser Talal
You should be able to find it if you search through the schematics I pointed to you above.
さんによる
コメントを追加
回答を追加する
Muddaser Talal さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 8
今までの合計 302
