メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Wont boot after running out of power
Yesterday my MacBook ran out of power, and when I restart the computer it just shows a grey background with a apple and the spinning wheel and a progress bar, when it has been running for a minute it automatically shuts down. I have tried resetting the rams, and tried resetting the efi firmware. But no luck. When I insert the installation disc it just freeze with the apple logo. I suspect that it has been trying to update firmware when closing down, but not sure. I also tried to insert a restoration of efi 1.9 disc, but wont accept it. Does anyone have an idea?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
It's the easiest thing to solve, first remove the battery and the AC adaptator , and press power button for 10 second . plug in the battery and the AC adaptater and start it up.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Plug it in a let it charge for an hour or so, then try it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Usually that loading bar means running disk check or trying to recover from a power save deep sleep. Charge battery for a while then do smc reset and pram reset then Try holding option key at boot and try going to recovery partition run disk check and repair disk permissions see if that work if still doesn't work try using installation disk again sometimes when booting to CDs it takes a ridiculous amount of time seen it take as long as half hour just to boot to a dang cd so be patient and wait up to 45 min to be safe if still doesn't work. If have another Mac you can try to boot with the other macs hd in yours and vise versa. To verify if can boot to either drive. Then if not try to get your hands on an apple hardware test cd for your model of laptop test hd and ram
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacob Bachmann さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 819
