メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
What should I do to stop recieving a temperature warning?
So, recently I bought a couple of broken iPhones from the internet and one of them is working just fine except that I keep getting that annoying message all over my screen about my iPhone needing to cool down. I’ve replaced the battery and even moved the logicboard to a different, working iPhone and the issue is still there. So it’s either a problem with the logicboard (which I find unlikely) or software. Any ideas? (btw, It’s not even getting much hot at all).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is your iPhone getting very hot? If so, there’s some sort of issue with the board that’s causing it to heat up to the point where the phone is considered unsafe to use. If it’s not heating up, just giving you an annoying notification, then there is likely some sort of issue with the temperature sensor on the board. Does the inside of the phone have any clues as to if it’s been water damaged before?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I mean as I said these are some used phones I bought and I opened'em all up and neither on the inside or the outside I see any signs of water damage, the phone is generally in a good condition, though I am not a technician so I might be wrong. I can provide some pictures If you want.
さんによる
Oh, and also, yeah technically it gets a little bit hot at first but after some time it's not even warm but the warning still appears.
さんによる
You could try doing a DFU restore on the phone to put fresh software onto it, that way software can be ruled out
さんによる
コメントを追加
回答を追加する
Joachim Sterna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 79
