メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
water damage indicator checking
hello for all wish you all nice day please can you tell how I can know if my iphone 8 plus has water damage i see some topics saying from the sim try slot and other said from motherboard can you please tell me how i can know using both methods ???
note : I attached an 8 plus motherboard tell me please where is the indicator
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Can you take a close up picture of the top left side of the board were the antennas connect please
さんによる
And a picture of the other side of the board
さんによる
@barriphone finally some one reply I was waiting since 10 hours this picture is just for information I want to know how I can determine if it has water damage or not please explain the method for me sir
さんによる
You need to take the board out and physical inspect it for corrosion. Check and see if it's been wet. Was water inside the phone. Pull off the black coveralls and check under them. The water Mark's don't really mean anything. If you have high humidity it can cause them to turn red. The only way to tell in to physical inspect it.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
the only way to really determine water damage is to open the phone and look at the LCI.
if you take a look at your picture of the motherboard you posted, see the square at the upper left. look at the thin part of the board where this connects. there is a white oval just above a flex connector. that's the LCI. if it contacts liquid, it will turn red.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tamer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 133
