メインコンテンツにスキップ
Lenovo IdeaPad Y500 is a gaming laptop, manufactured in 2013. The Lenovo IdeaPad Y500 is similar to the Lenovo IdeaPad Y400.
1回答 すべてを表示
Laptop LCD Compatibility with a cheaper one
Hello,
I have a Lenovo Ideapad Y500 with a bad LCD. The OEM one is a mode LP156WF1 (TL)(C1), however, the LP156WF1 (TL)(E1) is way cheaper. The only difference in the model is the E1 at the end.
Anyone knows if they are compatible? Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @guacaquico ,
According to this LP156WF1-TLC1 compatible model list they are not compatible. This is backed up by the LP156WF1-TLE1 compatible model list.
Looking at the panel specifications in the links below there are some differences between them, but the LVDS pinout (which is important) isn’t shown so you may have to get the datasheets for each panel to find out if you want to pursue it further.
These links will get you the datasheets but you have to register with the website to be able to download them. Scroll down the webpage to find the datasheet download section.
LP156WF1-TLC1
LP156WF1-TLE1
You may be able to source a cheaper panel using panel model numbers from the 1st list. Just a thought.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Wow, this is such a great answer. Thanks a lot man
さんによる
コメントを追加
回答を追加する
Juan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 119
