メインコンテンツにスキップ
2018年9月21日に発売されたAppleの第4世代スマートウォッチ、オプションでセルラー機能付きApple Watch用ガイドです。
124回答 すべてを表示
Power button is stuck
I have an apple watch series 4 that has the power button stuck pressed in. I had a protector cover on it that I never removed and it may have built up dirt and grime over time. I tried cleaning it around the edge of the button with a toothbrush and some water to no avail. When I connect the watch to the charger the apple icon comes on for a few seconds but then turns off due to the power button being stuck.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
3件の回答
最も参考になった回答
+1 for rinsing for a minute under warm water, which worked for me.
Context: after several days of swimming in salt and fresh water over the course of a week, after the last dip, the power button seemed to be stuck, going into Emergency SOS mode over and over again. After a reboot, the button was still stuck, so it could not boot: it would show the Apple logo for a few seconds then reboot again. Washing under warm water and clicking the button repeatedly fixed it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
From others who have had this issue, it looks like you can carefully rinse it under warm (not hot) water from the tap. Maybe this would remove whatever is causing the stick?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had this exact same problem after using the SUP case. I found a local iPhone repair shop that was able to replace the power button and the clicking mechanism beneath it and the watch is like new again. Hopefully you can find someone willing to give it a shot!
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
The same thing just happened to me with a Supcase. What did they charge for the repair.
さんによる
Same here with the Supcase I wouldn’t recommend the case for that.
さんによる
Same! SUPcase! Dang!
さんによる
Same thing is happening to me. Also had in a SUP case.
さんによる
The repair cost about 50 bucks I believe. Unfortunately maybe a year after that the battery started to die almost immediately and I had to get a new watch anyways.
さんによる
コメントを追加
回答を追加する
Freddy Gomez さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 22
過去 30 日: 85
今までの合計 15,921
