メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Stylo 4は、LGが2018年に発売したスタイラスペン搭載のミッドレンジAndroidスマートフォンです。モデル番号L713DLおよびQ710(AL、CS、MS、TS、ULM、ULS、US)で識別できます。
How do you fix 'moisture detected?'
Hello! I own a LG Stylo 4, and it hasnt been able to charge. It keeps saying moisture detected. This has happened before but turning it off and back on worked.. But now its dead so I cant charge it at all. Its been like this for over a month now.. Ive tried so many things, using a blowdryer to dry it out, ive tried charging it without the SM card, but it just wont work. Id get a wireless charger, but im not sure if there are any for my phone. Any solutions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It’s a common issue for phones nowadays to not be able to charge after sometime.
This can be either some ‘‘pocket residue’’ that has accumulated over time in the charging socket (which your phone interprets as moisture), or the socket itself has been pushed further inside in the device.
If any of these is the case, you can have it serviced at a phone shop, usually with minimum or no charge (depending on where you live and company policy).
See Moisture Detected, Charging is blocked.. ,may be helpful
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chelsi Hotz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 861
