メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
Screen Unresponsive, Ghost Touch
My daughter's iPhone XR started developing some weird symptoms where without input, it opens up apps, scrolls between screens, etc... After some googling, found that this is referred to as ghost touch or something. Couldn't find what the fix is to this problem though.
I tried resetting the iPhone to factory settings, even tried doing a reset/restore in DFU mode, to no avail. I wanna say this is maybe a hardware issue with the display (digitizer/glass) more so than a software issue. She had a case on it from day 1 but did drop it a few times, and even had a small crack on the screen towards one corner, not too bad though.
This being the case, I'm willing to replace the display myself, but before I shell out $100 on a new one, I wanted to see if anybody else experienced this issue and if so, did replacing the display fix the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
I'm having this exact same issue. Phone is pretty much useless right now. Keeps swiping constantly between apps and clicking whatever is at the bottom of the screen. Did you ever replace the screen, and if so did it fix the issue?
さんによる
Replacing the display assembly fixed the problem.
さんによる
コメントを追加
2件の回答
最も参考になった回答
You can buy a good quality screen for a iPhone XR for around 50 dollars. My guess is the dropping and possibly the crack can cause these issues. I would try replacing the screen.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes a new screen should fix the problem.
さんによる
コメントを追加
A new screen has not fixed my issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jose さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 36
今までの合計 1,857
