Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
ガイド
難易度:
簡単
5 - 10 minutes
ガイド
難易度:
中レベル
1 hour
ガイド
難易度:
中レベル
9 - 15 minutes
このアンサーは役に立ちましたか?
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
このアンサーは役に立ちましたか?
It's much cheaper just to replace the gasket or the valve of the tank.
過去 24時間: 6
過去 7 日: 15
過去 30 日: 43
今までの合計 2,030
