I need to replace the wire to the touch pad
I need to replace the wire/connection to the mouse pad
Hi @feetforme ,
Is the touchpad cable physically broken or it is just that the touchpad is not working?
The touchpad is part of the palmrest assembly.
I couldn’t locate a separate cable for the touchpad but if you search for Dell X3677, you will find suppliers of the complete assembly including the cable, Supplier -example only. Hover your mouse over the image to zoom in and view the cable. (D600 and D610 use the same palmrest/touchpad assembly)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 120
