QC 35 I turns itself back on
My QC35-I turns itself back on after a few minutes. I have found similar reports online. I believe it is due to a faulty power switch. I am not sure if the power switch needs replacing or cleaning. Can anyone help?
I took the right cover off and sprayed contact cleaner in the switch and cycled it a few times, put back together and it has been working for the past couple of weeks. IDK if you can just spray contact cleaner from the outside and get it into the switch because of the shape of the switch cover.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 11
過去 30 日: 47
今までの合計 2,384
1件のコメント
I’m going to try contact cleaner before I try taking them apart. I'll update it fixes it.
Rowdy Bedsaul さんによる
