メインコンテンツにスキップ
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
310回答 すべてを表示
21.5” late 2009 iMac work except Inbuilt display
I have 21.5” late 2009 iMac with 3.6ghz processor, 4gb ram.
I am from low economic group. I got this as donate.
When I bought This Used system, it was with incomplete OS X & Dead NVRAM battery.
1. I tried multiple times to install OS X with bootable Usb.
2. Reset smps
3. Prvm ram, clean physical ram. But installation showed multiple errors.
4. I connected to Apple help via call. Shared some articles but not fixed.
Problem started when I take help from technical person when he changed nvram battery.
1. Display stop working.
Then I can’t afford technical help so I decided to make it myself.
Before started Something I spent 2 months On various articles, Videos, faqs.
I found broken lvds cable and vertical sync cable while during nvram battery Change.
1. Replace same number lvds cable & vertical sync cable successfully without damaging anything.
2. Re greese both processors successfully.
3. Successfully Installed Mac OS X & upgraded.
4. Made Dygnotic  led worked.
5. Successfully installed other softwares.
6. System working fine on external display. With chimp sound.
Problem:
1. Unsuccessful To start Inbuilt display Again.
2. Multiple times checked cable connections. But unable success.
3. Display showing dark black, but I tried with torch it showing light visible display Elementals on screen.
Need help,
? Is this Lvds cable problem?
? Is this 12 volts display supply problem?
? Is this lcd led inverter board problem?
? Is this CFL tube inside lcd panel problem?
I know Without checking patients you can’t diagnose.
thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Google for louisrossmann forums. These are expert in such devices. He also has youtube channel (just search in youtube). You neeed to very careful to fix this. Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kailash Kamble さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 34
