Xfinity remote won't turn on Yamaha receiver
I installed a Yamaha RX-V385 receiver, and paired the Xfinity X-15 remote to it. The only thing controlled is the volume. Why won’t it turn the receiver on?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I contacted Xfinity, and worked through the fix from their side. I hadn’t followed their program process far enough. By using another available code, I was able to accomplish my goal.
このアンサーは役に立ちましたか?
Howbout telling us the code that worked, thanks alot
Sounds like the programming code you used is not complete for your receiver. You may want to get a remote decoder Generic Universal Tv Ir Remote Control Decoder Tester Infrared Remote Control Testing
Then manually create your own remote controller program for your Xfinity remote. That is if you can program it manually, I haven’t done the X-15 remote so I’m not sure if that’s an option.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 8
過去 30 日: 28
今までの合計 6,009
6 件のコメント
Use code 32467 to fix the issue
LeRoy Smith さんによる
You are a genius LeRoy
biancohaku さんによる
I have the Yamaha Rex v575. Xfinity remote works all functions but it turns the unit on and then immediately turns it off? Why?
timtheattorney さんによる
Thank you Leroy
stevethirtysix さんによる
You are most welcome
LeRoy Smith さんによる
1以上のコメントを表示
