Why I cant use the x button , and who can I fix it
this psp is can not use the x button ,so i open this but i can not see any problem so can someone tell me how can i fix my psp pls
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi There!
Are the rubbers fine? Is the button fine? Did you cleaned the right side input foil? If you can answer all the questions with “yes”, you should replace the right side input foil/flex cable.
このアンサーは役に立ちましたか?
where can i buy this
Hi! Depends on where you live. Example: http://store.richspsxparts.com/pspslpric... (US)
過去 24時間: 1
過去 7 日: 6
過去 30 日: 29
今までの合計 919
