メインコンテンツにスキップ
モデル番号A1285/8もしくは16GB容量
206回答 すべてを表示
coil for backlight problem
Joy indicated she solved this problem by replacing the coil. What is the coil number and where can one be purchased. I researched various forums and understand the 6R8 coil is used to repair the backlight problem on the Iphone, but I can not find a number or location to purchase a coil for the nano 4th gen Ipod. Any help would be greatly appreciated.
Thank you and have a great day.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
you can find them on Ebay here is just one listing
http://www.ebay.com/itm/New-6R8-Coil-App...
should be the same coil for the nano
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
order this coil >> http://www.aliexpress.com/product-gs/486... (its a little bit bigger) and place (glue) in the back with wiring 2 cables to solder points in the front.
dont forget to isulate with kapton tape!
http://dl.dropbox.com/u/35194698/iPod/Lo...
for me it works like a charm :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Looks good! Do you also have any ideas for the 5th gen nano with backlight problem? From my experience it seems more related to the tracks on pcb vanishing (maybe water damage) rather than a coil problem. What do you think?
さんによる
コメントを追加
回答を追加する
vic さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 2,213
