Battery and LCD panel are failing, can I operate it "headless" safely?
Hello!
After five years of use and abuse, my old PowerBook is showing its age. The DVD drive, main battery, and the PRAM battery are dead; and the LCD backlight, latch, and hinge are failing.
Because I can't justify the cost of the replacement battery and such, and due to the damaged LCD panel and hinge, I plan to use it as a small desktop Mac, with an external display, keyboard/mouse, and DVD drive attached. To prevent overheating, I would like to remove the LCD panel entirely. This way, I can simply place the "headless PowerBook" upright in a stand, behind an external 17" LCD monitor I have - a sort of "DIY iMac".
However, once I pull the LCD panel assembly out (Via this tutorial) is there anything I need to do to operate it safely without the panel? For example, do I need to make a cover for the back of the computer? What do I do with the monitor data and grounding cable?
Thanks for any tips!
この質問は役に立ちましたか?
3 件のコメント
Great question, one vote up for that. Hoping to hear responses soon, im eager to know the answer to this myself.
Majesty さんによる
Ditto - a second vote up
mayer さんによる
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list. Thanks so much.
mayer さんによる
