メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Flip 5は、2019年8月に発売された小型のポータブルBluetoothスピーカーです。IPX7の防水性能を備え、最大12時間のバッテリー駆動時間を実現しています。モデル:TT
Speaker works only when plugged in
Hello,
I bought a JBL Flip 5 to a shop. I got a price cut because it was the one that was available for testing at the shop.
BUT, I don't seem to be able to actually use it like a regular speaker, and I can’t get it back to the shop (far away).
What happens is that when it’s not plugged in to a power source it won't turn on.
When it's plugged to a power source it turns on by itself and no button is functioning. But my computer (running Debian GNU/Linux) sees it as an external soundcard (that is well done jbl!).
I am computer savvy so I have been trying many tricks to unlock it, exit whatsoever demo mode, by keeping Power and + pressed for 30 seconds, while plugged and while not; same with Power and Bluetooth; actually I tried every combination of power with other buttons and Bluetooth with other buttons, when plugged and when not, to no avail.
I also dismantled it and checked the battery state: it's absolutely full.
When I plug the speaker only the power button lights up, then the charging led (white), then the jbl sound, then that's it.
Is there something to do or am I stuck with a good but rather old-style batteryless wired speaker?
Thanks a lot!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I had the same exact issue with my speaker as well. I sent it to the local JBL repair shop (it was covered by warranty) and they fixed it. When I asked what was the problem they said there was an issue with a ribbon cable.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I’m having the same issue but I’m pretty sure my warranty is done
さんによる
コメントを追加
回答を追加する
Kim mobile さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 32
今までの合計 1,532
