Refrigerator is worming on the outside
My refrigerator and freezer is Collings properly however the outer part of the refrigerator is very hot.
I'm also getting a weired error on the screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It is normal for a refrigerator to be warm on the sides and top. The refrigerator cools by removing the warm air inside it. But if the outside is hot to touch, I’d suggest cleaning the condenser coils underneath the refrigerator. Some are accessible from the front by removing the bottom toe plate and vacuuming the dust from the coils. Some are behind the unit. Unplug the refrigerator and slide it away from the wall so you can remove the rear access panel and vacuum out the dust. This should be done at least once a year. This will help your refrigerator in every way and prolong its life.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 36
今までの合計 936
