CMOS battery of an A1286
how to replace the little CMOS battery of an A1286 MACBOOK PRO, as i cant find it.
does it have any?
if yes, please send instructions
thanks
lcg
この質問は役に立ちましたか?
does it have any?
thanks
lcg
この質問は役に立ちましたか?
The A1286 uses a super capacitor for the time and date - not a coin cell like the older MacBooks. Unlike older Macs where it can be that battery on portables, it's either due to a tired battery or the capacitor needs to be replaced.
Since you own a 2011, my strong recommendation to fix this is to buy a 2012 motherboard (or a whole 2012 laptop and move the hard drive), if the battery does not help. The GPUs in these are ticking time bombs.
While the GPU is a problem, it can be disabled if it's bad thankfully. dosdude1 has a patch to fix it in software but it isn't permanent and will be re-enabled if you reset the NVRAM. In addition, the driver gets removed so it will behave weird if it is reset once patched. The other option is to use gfxcardstatus to disable it manually but it will still remain active in NVRAM.
このアンサーは役に立ちましたか?
where is the supercap located and what type is it for replacement?
thanks
@Livio Ghisleni Try changing the battery first; it's much easier.
If it's the board, we need to know which one you have. Enter the serial number here.
We need that to find your board schematic and locate the cap.
even with no power supply the fans do run and the LEDs are illuminating the keyboard, too. over a long time. let me guess the big battery is not the problem.
but when i hook the ps in, the connector goes on orange colour.
thing is, i dont have a big battery for replacement.
tomorrow i will check the number of the board and let you know.
thanks
Livio
hello Nick
the number on the PCB says:
APPLE © 2009
820-2565-A
see also the pictures attached to the answer
thanks
L
the number in my previous answer is the PCB-type.
the SN of the PCB however i cannot find.
but here is the SN imprinted on the back cover of the macbook pro:
CO2HF1D4DV7P
過去 24時間: 1
過去 7 日: 6
過去 30 日: 58
今までの合計 1,994
1件のコメント
This question was migrated from https://meta.ifixit.com/Answers.
iRobot さんによる
