メインコンテンツにスキップ
The Samsung Galaxy A40 was released in April 2019.
28回答 すべてを表示
Samsung A40 stopped charging yesterday following him dropping it.
Hi, my brothers Samsung A40 stopped charging yesterday following him dropping it, resulting in the phone being bent. The phone is now completely dead and he has a replacement in the mail. However, he doesn’t want to lose all of his images and contacts. Any suggestions?
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
最も参考になった回答
do as in the movie. or press the phone on the back in the fingerprint area. hold and connect the charger
https://youtu.be/SS_nAF4tMFk
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
OMG, this worked ! Thank you Jacek Sopel.
さんによる
'or press the phone on the back in the fingerprint area'
Genius, worked
さんによる
It really worked my phone started charging
さんによる
コメントを追加
You have problem with:
# Charging dock (Charging port or FPC connector) - needs replacement.
# Main flex cable - needs replacement.
# FPC connector on the motherboard - needs repair from technician.
Samsung Galaxy A40 - does not charge - how to diagnose the problem
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
He can open it up and check the connections for the battery and the charging port, a connection could have been knocked loose. He could also connect a battery to the phone and extract the data or take the battery out and charge it with a battery charger you can pick up on Amazon for 20 dollars
do you have to return the phone? If so will you get in trouble if you open the phone? You can have a repair shop take the back cover off and charge the battery and get the data.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chloe Stephens さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 85
今までの合計 3,213
