メインコンテンツにスキップ
Motorola Moto Z3 Playは2018年6月に発売されました。6インチの画面と取り外し不可能なリチウムイオン3000mAhバッテリーを搭載しています。 リアカメラは12MP、フロントカメラは8MPです。 モデル番号XT1929-3、XT1929-4およびXT1929-8です。
14回答 すべてを表示
Best way to get water out of the power button?
I dropped my Z3 (in an otterbox) in some water yesterday and it seemed to be doing fine for a few hours, but then it started acting as if the power button was being constantly held down, which led me to believe that there was water closing the circuit that the button usually would. Is there any good way to get the water/moisture out from near the power button without completely taking the phone apart? I’ve tried putting it in the fridge in a bag of rice to get the moisture to condense, and heating it with a hair dryer to get the moisture to evaporate out, but it hasn’t done too much so far.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The only thing you can do is pull it apart and unhook the battery immediately and dry it with warm air. Don't charged it. Once it's wet it starts corroding immediately especially with power going through it. Clean any corrosion with a qtip and alcohol or a soft brush like a toothbrush. But the issue is that once it's been wet it's likely to cause issues and could stop working at anytime. Repair shops won't work on water damaged phones except to retrieve data.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Noa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 353
